Front sway bar
Old Nov 4, 2014 | 10:05 AM
07street's Avatar
Default Front sway bar
Before I bought my JKU the dealership had a lift installed. Its a 2.5 inch Rough Country. Very basic kit I'm sure. However the front swaybar link is the stock part and it wasnt replaced in the kit. Is there an issue keeping it this way or should I have it replaced with a longer link. If so what do I need to get? Im sure a quick disconnect but which one do you recommend I should use.
thanks in advance and hope this made sense
Old Nov 4, 2014 | 10:46 AM
JKBud's Avatar
You will need links for a 2.5 lift, look at JKS and teraflex.
Old Nov 4, 2014 | 11:44 AM
Mark Doiron's Avatar
Most of the kits come with new links for the rear swaybar. You then take the rear swaybar links and move them to the front. Unless you have quick discos, as mentioned above by JKBud. You do want to fix it.
Old Nov 4, 2014 | 12:34 PM
07street's Avatar
Thats what i thought. I didnt think the sway bar should be at such an angle. I cant believe they didnt move the links. I guess i will order the quick disconnect ones.
Old Nov 6, 2014 | 05:35 AM
RoughCountry's Avatar
Former Vendor
We can get you discos or standard links whichever you would prefer. Just let me know.
Old Nov 6, 2014 | 03:48 PM
07street's Avatar
Attachment 583180
Ben
Again thank you for your help today and looking forward to getting the quick disconnects and rear sway bar links installed.
Also i want to say that you and your company are TOP NOTCH and I will let everyone know what a pleasure it was to do business you and how customer service minded you and Rough Country are.
Again
Thank You Sir !!
Troy
