Rock Krawler Max Travel vs. X-Factor
Old Nov 10, 2014 | 08:41 AM
ShutterBug's Avatar
Question Rock Krawler Max Travel vs. X-Factor
So, the time has come for me to get a full suspension lift for my 2014 2 door JK.
I am set on Rock Krawler - there is no debate on this, I will not change my mind.
But I am wavering between the 2.5" X-Factor and the Max Travel. The key difference is the X-Factor includes a rear adjustable track bar and upper adjustable arms.
I am upgrading my 33" tires to 35" this week and currently have no plans on going bigger - but I said the same thing about my 33's Let's assume for the sake of argument that I won't go past 35" tires.
Questions for the lift gurus:
1. Does having a rear adjustable track bar make a difference in handling? Or does it only come into play in higher lifts.
2. Does having upper adjustable control arms add any additional flex to the suspension? They do push the rear axle back an inch, but like I said, no 37s for me.
I can always add them later, but it's a $500 upgrade to do it now vs. $700+ later. If the difference in flex is minimal, then I can put this off to another time.
Thanks!
Old Nov 10, 2014 | 09:17 AM
mattyk's Avatar
Veteran: Navy
Go X factor. If you go max travel you will have to replace a set of lower control arms because the max travel arms are not compatible with the X factor uppers. You could go max and try to sell the LCAs later but you know you won't get near what you paid for them. The rear adj track at is worth it as well. I had to readjust mine after wheeling because my flange on rear DS started rubbing my gas tank skid. Wouldn't have been able to fix that without the adj track bar.
Pay now, save later.
Besides. The X factor is a very comfy DD with amazing off-road capabilities.
Old Nov 10, 2014 | 12:39 PM
ShutterBug's Avatar
OK. This all makes a ton of sense. I think the X-Factor is the way to go. At least if (or when) I go to 37s, I'll be in a better position. But I wouldn't do that until I upgrade my front axle (either a D44 or truss my D30).
Old Nov 10, 2014 | 01:50 PM
Rock Krawler Suspension's Avatar
Former Vendor
Thanks!
Mattyk said it well, to add the other components later would require a new set of rear lowers. Definitely do-able but If thats your ultimate goal it may be easier to do it all up front for you.
RK
Old Nov 10, 2014 | 06:53 PM
jsukey's Avatar
Default Go X-Factor!
I installed the 2.5 X-Factor a little over a year ago, and I absolutely love it! I'm running the Bilstein 5150 longtravel shocks with the Currie spring retainers. The ride is absolutely amazing, as well as the flex. You won't be disappointed.
Old Nov 10, 2014 | 09:12 PM
mds22's Avatar
I got the 3.5 RK mid arm flex, then spent a sh*t ton of $$ upgrading. Get the XFactor with the RK pro high steer. You will be happy you did
Old Nov 11, 2014 | 07:02 AM
ShutterBug's Avatar
RK
Always good to hear it from the manufacturer. I'm convinced the X-Factor is the right lift for me.
Help me answer another related question. With this lift on my 2 door, with Bilstein 5100 shocks, 35" tires and Bushwacker flat fenders, what size bump stops (if any) will I need?
Old Nov 11, 2014 | 02:03 PM
Former Vendor
Go right to our website and pick the kit that you are looking at, there is a shock options tab under the description and there will be Bilstein 5100 part numbers and the coinciding bump stop sizes for those part numbers!
RK
Old Nov 12, 2014 | 09:15 AM
RiverCityOffroad's Avatar
Former Vendor
I would run the longer Bilsteins on your two door with 3" bump stops. That is the setup that I have run in the past with both Bilsteins and Fox shocks. The Fox shocks will ride a little stiff on the two door, but you gain an inch or more of droop with them.
We offer a package deal on the Rock Krawler systems that take all of the guess work out of things if you're interested.
Marcus
Old Nov 12, 2014 | 09:41 AM
Ol' Bob's Avatar
Go x-factor.. You won't regret it. Very complete all at one shot. I love mine.
