Back to Stock Suspension
I have 3.5 to 4 inch lift, used to run 37s, but not running 35x15s. I'd like to go with a lower, wider look and my question is...Can I just change out the springs to 19/60 front and rear and keep the 4" hardware - steering arm, control arms, sway bar link, etc. or do I have to change out everything? My gut feeling is the later but wanted to check. Apologize in advance if this is an obvious questions but am curious if I have to go through all the work just to lower my jeep by 2 inches. Appreciate any guidance.
You should be able to keep adjustable control arms and drag links, if they will adjust to stock length. You will need stock length sway bar links and shocks. Brake lines may also need to be replaced with stock length brake lines.
