Front driveshaft disengage.
Not sure if I even right on this but I believe I am. I have. 2013 JKRU that I have been slowly modifying. I disconnected the front driveshaft so I could get the axle to droop more on driverside and I'm pretty sure shaft was spinning so I put it in 4wd to stop it in order to loosen bolts(I just reached in and shifted transfer case to 4h without jeep being on or keys in ignition). Anyways everything is back together so I went to turn jeep around in my driveway and had a hell of a time turning. After putting it back in the garage I lifted driverside tire off the ground and I couldn't get it to spin. No 4wd lights are on in the dash.
Just lifted front tires off the ground and both spin the same direction. I would assume my problem has to do with trussing front axle and removing axle shafts to do ball joints. I hit the switch to activate lockers and the lights came on on the dash and shut off when I hit the switch again but front is still locked. Any suggestions?
I'll try disconnecting the batteries
Rear light stays on but front only blinks. Pulling 2 sensors on axle when I welded on truss have anything to do with it or reinstalling axleshafts after balljoints?
Found the problem. I pulled the front locker sensor out when I did the axle truss and when I put it back in the plunger to the sensor is on the wrong side of plate so now I need to figure out how to get it on the correct side.
Having one person in cab working locker switch while other person takes small flat blade screw driver
To move plunger to other side of plate. ( this is with diff cover off I think ) ....
