3 Inch Suspension
I have a 2013 Sahara Unlimited and I plan on ordering a 3 inch Taraflex suspension lift. Can I use run the 255/70/18 Bridgestone Dueler now until I purchase 35s? What else do I need to consider when lifting with these spec?
To give you a direct answer it is yes. You can run those on a monster truck. Will it look funny? A little.
Yeah, they are hidden and really hard to find without having them pointed out. When you first click into the Modified Tech area, right at the top you will see a few threads with a gray background that say something like:
Sticky: Modified Tech FAQ's - Answers to questions every newbie has
Sticky: My Thoughts on Lifts
These will answer a bunch of questions, and probably give you a dozen more that you hadn't even thought of.
