Ingenious or ineffective way to keep water OUT
Old Nov 21, 2014 | 12:24 PM
Rescue7's Avatar
Default Ingenious or ineffective way to keep water OUT
Would one benefit from keeping the cabin pressurized with the HVAC on the jeep during a water crossing? with a constant outflow of air anywhere water could get in the water would have to over power the cabin pressure which can be impressive. " try closing the door with the heat blasting". it almost doesn't want to close. What are peoples thoughts.
Old Nov 21, 2014 | 12:59 PM
mcochrun13's Avatar
The vent in the tailgate would prevent any pressure from building up inside the cabin.
Old Nov 21, 2014 | 01:05 PM
Jeepstin12's Avatar
this. And, your HVAC would have to produce enough pressure to push back the water intrusion. If it's that much of a concern, don't go in deep water.
Old Nov 21, 2014 | 03:18 PM
Vladimer's Avatar
If it was a sealed box it might help the door seals... but the tailgate vent is of good size. I can't imagine there being enough air pressure to keep the water from coming in through the tailgate vent.
Try it with and without and let us know!
Old Nov 22, 2014 | 07:18 AM
dmwil's Avatar
I doubt it would help in a water crossing, but in the car wash with the soft top on, I know it helps a little. When the soap is on, I can see bubbles on the outside of gaps around the windows and top.
It certainly can't hurt, though.
Old Nov 22, 2014 | 09:52 AM
JE8154's Avatar
You're not going to be able to do that.
