springs or leveling kit
Old Nov 25, 2014 | 01:34 PM
pps9mm's Avatar
Default springs or leveling kit
hi all,Want to level up my 2010 jk 2dr,it has 14/56 springs now have a chanse to grab some 18/59 springs for 75.00 brand new,a little lift wouldnt hurt,not looking to go any bigger then 33's,should i do the springs or the tera flex BB,also so glad to be a part of this addiction.
Old Nov 25, 2014 | 02:39 PM
Tripletsi's Avatar
I did the same spring swap with my girlfriend's JK on 33's and it looks perfect. Just enough lift to get rid of the "bubble tire" look. Highly suggest it.
Old Nov 25, 2014 | 02:57 PM
fultonromero12's Avatar
That's a good price for those springs. Do it! You won't regret it.
Sent from my iPad using JK-Forum
Old Nov 25, 2014 | 03:12 PM
pps9mm's Avatar
thanks tripletsi it does look good hows the ride better?
Old Nov 25, 2014 | 03:24 PM
Tripletsi's Avatar
No problem, hope you enjoy this forum, I've learned tons on here! The JK rides just a little bit stiffer, I added Rubicon shocks at the same time so that's partly why. I've got 3 speed bumps leading in/out of my townhouse complex so it was pretty easy to tell.
Old Nov 25, 2014 | 03:25 PM
catahoula's Avatar
I did both and love it. Real good price DO NOT SLEEP ON IT!
Old Nov 25, 2014 | 03:26 PM
pjmjk's Avatar
That's definitely a good price.
Old Nov 25, 2014 | 03:36 PM
webejeepin's Avatar
I have a JKU but from all I've read here those are good spring numbers and a fair price.
Like other JK folks have posted....DO IT
And of course enjoy and wave
Old Nov 25, 2014 | 03:51 PM
ricon's Avatar
I went from 14/56 to 18/60 and added the shocks from a jku. It will absolutely work. I gained nearly 2 inches all the way around. You won't be disappointed. And later, upgrade to a nice set of shocks to help with the ride, if needed. 33s will be fine with that.
You may need a spacer up front if there is a rake. Maybe 3/4 inch, depends on the weight you have in front.
Old Nov 26, 2014 | 02:13 AM
pps9mm's Avatar
thanks guys im getting them today,ill post some befores and afters.thanks again happy holidays to all.
