JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Steering in 4 wheel drive
Old Nov 27, 2014 | 07:39 AM
Rovercross's Avatar
Default Steering in 4 wheel drive
I bought my first JK I hate to ask a stupid qeustion but when in four wheel drive the steering really becomes hard to steer. Is this normal when in four wheel drive ?
Old Nov 27, 2014 | 07:45 AM
TheDoubleD's Avatar
This will explain it:
How the Jeep Wrangler 4x4 Works
https://www.youtube.com/watch?v=G9AbWnRQCac
Old Nov 27, 2014 | 07:47 AM
mcochrun13's Avatar
Your tires are all turning at the same speed. When you turn the inside tires don't turn as fast as the outside tires, causing this to happen. If you are on a surface that is not loose or slippery in some way (dirt, mud, snow, ice) this will happen.
Old Nov 27, 2014 | 07:56 AM
ronjenx's Avatar
You shouldn't notice it as much when on dirt/snow/ice. If you do, it's an early indicator of u-joints beginning to seize.
Avoid 4wd on dry pavement, and other good-traction situations.
To add to the posts above, when turned left or right, the front u-joints speed up and slow down twice with each revolution. This makes them want to be straight, which makes turning more difficult.
Old Nov 27, 2014 | 09:19 AM
Rovercross's Avatar
Thanks fellow Jeepers for piece of mine. Happy Thanksgiving .
