Aligment question
Old Dec 5, 2014 | 03:21 PM
htm7765's Avatar
Default Aligment question
I have checked older post but was unable to find the info I am hoping to get. I installed a zone off road 2 inch lift not springs just spacers I did not want to change the ride, it drives fine don't really notice a difference from the stock ride but I finally got around to getting the alignment check and I found my caster is almost 2 degrees low on both sides for the sake of a number say 2 degrees, anyway I was hoping to get away with the OE bolt and eccentric washer kit to correct it. Front end is tight if this won't work what would I be looking at to correct this spec 2011 2dr sport
Thanks
Old Dec 5, 2014 | 03:38 PM
Invest2m4's Avatar
Keep it simple and get the AEV geometry correction brackets. Stay away from the cams. It's that simple
Old Dec 5, 2014 | 03:44 PM
htm7765's Avatar
Thanks but reading about them on AEV site 2.5 inch lift minimum required sounds like my 2 inch might be an issue
Old Dec 5, 2014 | 03:50 PM
nthinuf's Avatar
Cam Bolts, Brackets, one set of either Fixed Control Arms or Adjustable Control Arms. They each have pro's/con's. Cams are cheap, but have been known to slip and put you right back at the low caster, but may not be a bad call for onroad only with a low budget. Several mfg's make longer/shorter fixed control arms to adjust the caster, but you will need to check into them to see how much caster they adjust for. Adjustable control arms are the most expensive, but if you go for front uppers rather than lowers you can save some money.
Old Dec 5, 2014 | 03:54 PM
htm7765's Avatar
Ok I will look into those if I can get the cam washers to correct it to keep it from slipping back what would you thing about a small tax weld ?
I also plan on doing the AEV measurement and gather some more info and make the best decision thank you
Old Dec 5, 2014 | 04:01 PM
ade's Avatar
ade
2x on the AEV brackets. Very nice and strong.
Old Dec 5, 2014 | 04:44 PM
Invest2m4's Avatar
Based on what you said, the AEV brackets are great. They have three holes. You're over 1 degree out of spec. The brackets have three holes. You'll be fine at the first hole and may even find the second better. With a lift, running 5* is a good place to be for caster.
Way back in the day, I started with a 2" budget boost. The AEV brackets got me right where I needed to and I used the middle hole.
Old Dec 5, 2014 | 04:47 PM
Invest2m4's Avatar
You like AEV, but not MetalCloak? Is this the twilight zone?! Haha. Just messing with you
Old Dec 5, 2014 | 04:56 PM
htm7765's Avatar
I guess I will placing an order
Old Dec 6, 2014 | 04:57 AM
kjeeper10's Avatar
Vet Army
Why would caster be that low at 2" ?
He's right AEV list a min coil measurement to run their brackets. I would do arms in this situation.
Either uppers or fixed length lowers... Both will be cheaper.
