Kilby Trail Boss Shock Skid Plates
Just installed the new Kilby Trail Boss Shock Skids. Here are a few pictures.
So far so good. I will trail trial these on Saturday and report any problems. They seem very sturdy and do not reduce ground clearance by much (maybe 1/4").
I do a lot of rock crawling and have smashed up my shock mounts pretty good. You normally don't hear the damage when you hit these on the trail. If you slide off a rock to the inside of the tire you will bump the bracket. Of all the spots that have scraped on my underside it is these d@mn shock brackets.
These are a good idea..however, kilby needs to get with it. I said this in a previous post...they are over charging you out the wazzooo for those things. You can spend 30$, and get some relocation brackets from Rock Crawler, have more axle drop in the rear, and they wont get hung up on anything any more
