Fuel Off-road ANZA Beadlocks D116
Old Jan 6, 2015 | 04:51 PM
BAJA TYM's Avatar
Default Fuel Off-road ANZA Beadlocks D116
Anyone running these (Fuel Off-road ANZA Beadlocks - D116)? I've run searches on various forums and haven't found much (if anything). An feedback would be appreciated.
Thanks -- James
Old Jan 7, 2015 | 10:55 AM
JE8154's Avatar
They look nice, but looks like they only come in 4.5" back space. Most guys that see the need for bead locks are running bigger tires that require more back spacing. So you probably won't find many guys running them.
Old Jan 7, 2015 | 03:08 PM
BAJA TYM's Avatar
Interesting. I've never run Beadlocks, so my knowledge is limited. As to back spacing, what's typically required... When you say larger tires, what size are you referring to?
Thanks for the reply.
--James
Old Jan 7, 2015 | 04:53 PM
JE8154's Avatar
--James
37's usually require about 4" or less to avoid rubbing. 35's should be fine with 4.5".
Old Jan 8, 2015 | 02:13 PM
BAJA TYM's Avatar
Great info, thanks.
