TF coil leveling kit + spacers
Old Jan 19, 2015 | 12:13 PM
BlackRubi1's Avatar
Default TF coil leveling kit + spacers
I have a jku with a TF coil leveling kit but wondering if I could add 1 inch spacers all around to get so more clearance. Would that effect the sway bar discos?? Thanks
Old Jan 19, 2015 | 12:27 PM
mikeJKUR's Avatar
What shocks are you running now? What is your caster angle at now?
Old Jan 19, 2015 | 01:14 PM
nthinuf's Avatar
Sure you can. But, with extra height comes more issues that you may or may not need to address. Caster/pinion, swaybars angled down, stretched brakelines, extended shocks, steeper driveshaft angles, offset axles, etc. Taller lifts tend to come with extra components for a reason, research a bit so you know what they all do so that you can make some more informed decisions.
Old Jan 19, 2015 | 02:16 PM
BlackRubi1's Avatar
Thank you! I'm running stock rubi shocks not sure about castor angle but I have a TF adjustable trackbar
Old Jan 19, 2015 | 02:23 PM
BlackRubi1's Avatar
Was out on the trails today, I'm bumping my fenders like crazy :/ not a huge fan of the trimmed fender look
Old Jan 19, 2015 | 02:42 PM
mikeJKUR's Avatar
What size tires are you running? You probably need to add bump stops to limit your up travel.
Your caster angle numbers would be on your alignment sheet. Its probably low with your 1.5. If you went up a 2.5 it would be really off.
Old Jan 19, 2015 | 03:27 PM
BlackRubi1's Avatar
33 trail grapplers
