Steering advice - 2.5" lift with 35's
Hey everyone, new to the steering modifications and need some advice. I have the AEV Dualsport XT Suspension system, and just recently removed the sway bar end link relocation brackets to install quick disconnect end links. I am noticing the bump steer issue and also just feels like my Jeep is all over the place while on the highway at higher speeds. I have been trying to research and do a ton of reading and wondering what I should do to fix this issue.
New steering stabilizer?
New tie rod and/or drag link?
Flip existing Tie Rod?
New track bar?
**My suspension came with an AEV rear track bar as well, not sure the relevance.
Thanks for any help so I can get this corrected, as my Jeep is my daily commuter.
New track bar?
Did you purchase the AEV correction brackets with that lift? I noticed a huge difference when I didn't have mine installed with it. I even went a little crazy and purchased the Fox ATS stabilizer. While some with argue it's a waste of money I also noticed a significant improvement with it installed. Between the brackets and the stabilizer I very happy with my steering. Also be sure your tires are at the right pressure as that can greatly affect your steering.
Don't waste you money on a new steering stabilizer; surprisingly the stock ss works pretty well. You might want to relocated the ss to the top of the tie rod with a relocation bracket if you whee though.
The brackets will rotate the axle back to a happy place. You also have the option of adjustable lower control arms, but the brackets are much easier to deal with, cost less, and don't require an alignment.
Also, check the torque on all the control arm and track bar bolts. And confirm that you torqued them when the Jeep was on the ground at ride height. Common issues are people don't loosen the bolts to put coils in or they torque the bolts with the Jeep off the ground. Both will cause bind in the bushings and lead to poor steering and premature wear on the bushings. And improperly torqued bolts will also cause steering issues.
That makes sense. I have not checked the torque on any of the steering components as I purchased the vehicle with the lift installed already. I will do that when I get home today. Do you know the torque settings off hand, if not I can look them up?
So I do not need to replace anything, rather just buy these AEV brackets and relo the stabilizer if I wheel (which I do). Correct?
If you wheel, then you may want to consider adjustable lower control arms. The relo brackets hang low and eat a lot of trail. If you do go that route, you don't need anything else.
