Moisture/condensation on the inside of truck lite lens?
I have a set of TL 27270c leds that I bought from NR4x4 about 2 years ago. One of them gets moisture on the inside of the lens whenever it rains or I wash it. The other stays dry. They both work fine but I am afraid that eventually it will fog up enough that it will be cloudy and not come back to clear. Both lights have the same little patch/seal vent cover on the back. Is this something that Truck lite will replace even tho the light is still working? I have emailed them a couple of times but have never heard back. Anybody else get moisture/condensation on the inside of the lens? thanks
Living in SW Florida I have plenty of moisture. I've had my Truck Lites for almost a year and so far so good. Have you checked to make sure the one is securely positioned?
Pull the light out and check the top/rear of the lamp, there should be a Gore-Tex patch over the breather hole. If it is still there you could have a bad seal on the lens, if it fell off you should give the vendor who sold the light to you a call to see about a replacement patch or light. Good luck
