Flat Fender kits for 2dr JK, any thoughts?
Old Jan 22, 2015 | 03:13 PM
measty's Avatar
Default Flat Fender kits for 2dr JK, any thoughts?
I have an 08 JK 2dr that's in the body shop to fix somw trail damage and I thought as long as it was there I might as well have them do the fenders for me. I think the stock JK fenders are about the ugliest things ever manufactured.
Does anyone have any experience with specific brands they'd like to share? Plastic vs Steel or even aluminum? One issue I have heard is at least one brand will not sell you replacement hardware if you happen to snap something on the trail. Stuff like that is helpful too.
Thanks in advance for any help.
Mike
Old Jan 22, 2015 | 03:20 PM
ade's Avatar
ade
PSC and Genright make nice fenders. Steel will add 200 lbs to your rig. You can also look at trimming the stock ones.
Old Jan 22, 2015 | 03:41 PM
afpilot82's Avatar
JK-Forum Ambassador
There are a few flat fender threads in the show & tell section, I'd start looking there.
Old Jan 22, 2015 | 05:15 PM
measty's Avatar
didn't think about the extra weight, thanks for pointing that out
Old Jan 22, 2015 | 06:21 PM
Waldo_88's Avatar
I trimmed my stock ones and really think they are the best for my application. It took me a few hours to trim and didn't cost me a dime. Instead of bending or damaging the body, they simply flex or pop off if you rub a tree or rock without damaging anything. You can buy the replacement clips from the stealership for a few bucks a piece.
Old Jan 22, 2015 | 06:56 PM
rsbmg's Avatar
I just got Nemesis very nice........
Old Jan 22, 2015 | 11:44 PM
shj_jeep's Avatar
I have seen smittybilt xrc fender flares
They will give you high clearance and they are so narrow
Old Jan 23, 2015 | 05:22 AM
Baddkarmaracing's Avatar
These are the smitty bilt xrc flares at stock height with 35's
Old Jan 24, 2015 | 12:01 PM
wharthog69's Avatar
Xenon Wide-Flat Flares. I had to go wide to get tire coverage between spacers and backspacing changes. I did destroy one on the trail and ordered a replacement no problem. It flexed a huge amount before it finally broke. Not Xenon's issue at all, I had it up against a tree. I bought the originials used, they came with the plexiglass supports used to keep them from getting droopy when they soften in the heat. Sanded them down, self-etching primer, couple of coats of spray on bedliner later:
It looks a little different now (all grown up)
