Ten factroy axle shaft info
Was getting ready to order some front axle shafts from ten factory . Does anyone have anything bad to say about them ? Did anyone have any problems with the shafts not sealing around the seals ?
I've used them on three different jeeps. Never had an issue. Their warranty covers shafts and any damage that may have occurred, like a grenaded diff. They also cover phlanges on rear. Good shafts.
sent from my work leash
Make sure you match up the axles to your factory ones. I've seen a couple times where the long shaft had a seal race that was not the correct diameter. They took care of it but it was a bit of a pain in the ass.
