Change rear axle seals?
I'm sliding the rear axles out a bit to pull the differential carrier. My Jeep is a 2010 JKUS with 60k miles. The rear axle seals aren't leaking now. Should I grind off the keepers and bearings and change the rear seals while I have things apart?
