FOX ATS Warning!
Old Jan 31, 2015 | 02:15 PM
FDHog's Avatar
Default FOX ATS Warning!
Any of you guys running the ATS Stabilizer should check your Tie Rod clamp. Mine took a crap today.
The factory installed bolt holding the bracket to the shock came loose sending my unit crashing to the ground. it got twisted under the Jeep and the mounting end snapped and the piston rod got chewed up.
Check your clamp. It should've been installed with red loctite from the factory.
I sent an email with pics to FOX to see what they have to say. Hopefully it'll be a warranty issue.Click image for larger version
ID:	594630Click image for larger version
ID:	594631Click image for larger version
Old Feb 1, 2015 | 05:08 AM
HALCYONTSF's Avatar
Thanks for the post. I'm going to check on mine now.
Sent from my iPad using JK-Forum
Old Feb 1, 2015 | 06:19 AM
Monte417's Avatar
Funny you posted this I took mine down yesterday to do some front end work and that Bolt was loose as shit. I didn't have any locktite on me but after seeing your pics I'm going out to put some on now that's for sure
Old Feb 1, 2015 | 01:28 PM
FDHog's Avatar
I sent an email with pics to Fox. Also got in touch with Globex who did my lift. They are also gonna call Fox. See if I can get a new unit out of them.
Old Feb 1, 2015 | 01:46 PM
evoviii2jk's Avatar
Mine is currently at Fox for a second rebuild do to the whole body rolling over and rubbing the tie rod. The tie rod side mount freely spins. As in the whole shock spins over
Old Feb 1, 2015 | 01:53 PM
FDHog's Avatar
Seems like they have a few bugs to fix.
Old Feb 1, 2015 | 02:09 PM
46chevytruck's Avatar
Mine did the same. I sent in photos and never heard back. I need to followup. Way too expensive to have issues like this.
What did they charge to rebuild it?
Old Feb 1, 2015 | 04:31 PM
Maertz's Avatar
Hmmm for the cost of that thing you could have bought a hydro assist kit....
Old Feb 1, 2015 | 05:19 PM
DJ1's Avatar
DJ1
Former Member
Thanks for the heads up on the tie rod clamp. Although for the guys that have the shock body roll over, I don't see how that's possible unless you loosened the allen screw or didn't tighten it back up so it wouldn't move. Or maybe it just doesn't clamp down hard enough but I haven't seen any movement for the few months I've had it.
Old Feb 1, 2015 | 06:09 PM
FDHog's Avatar
My clamp never budged either. It just came apart. 7 months with light offroad use.
