Overlanding with a Rubi, opinions on gusseting?
Have a 2013 Rubi with 2.5" AEV lift, AEV control arm relocation brackets and running 35s MTR Kevlar. I am in the process of installing Synergy Front Track Bar Brace & Sector Shaft Brace with JKS Manufacturing Steering Stabilizer Relocation Bracket that will be welded on the axle end to help brace the bracket that holds the trackbar. Im not a rock crawler, but do go over rocks when I have to. We would like to do the Alpine loop in CO and some of the trails around Ouray this coming summer and just looking hear some feedback on gussetting the knuckles... I know it wouldn't hurt, but Im not an exttreme crawler. I usually take the easier and safer route if there is one... thoughts on gusseting for overland or street use type jeeps. TIA
Here are the braces Im adding...
http://www.quadratec.com/products/16315_60XX_C_PG.htm
http://www.quadratec.com/products/16007_0102.htm
http://www.quadratec.com/products/16007_0105.htm
Since you are putting that much money and effort into steering upgrades, and you are already welding brackets onto the axle, I am curious why you are trying to talk yourself out of gussets?
Reason being is Im a DIYer and never welded before, I dont like shops...
Depends on the person doing the welding. Too much heat will melt the plastic inserts/ fry the grease, so the general recommendation is to take your time, switch back and forth to different areas, and use wet towels or whatever to keep it cool. Lots of how-to threads and videos to browse through for pointers.
as for welding... im just gonna go with a 120v fluxcore type welding... should the sensors, lockers etc (electricals) be pulled off the axles for isolation... Im not talking about heat protection but more about grounding and noise protection that may be fed into the cpu of the jeep. Anyone know the rule of them when it comes to the subject of protecting electronics when welding?
