Hawse Fairlead with Prolink Thimble & Front License Plate
Old Feb 3, 2015 | 06:35 AM
MAG00's Avatar
Default Hawse Fairlead with Prolink Thimble & Front License Plate
I have been searching for a good. clean solution to mounting my front license plate (required here in Texas) while having a Factor 55 Prolink thimble and hawse fairlead. I came across the following product and was curious if any others have seen this or use it. Any thoughts on this product from your initial review (used or not)? Thanks.
Fairlead to move thimble out of the way
License plate bracket to be used with the fairlead
Any thoughts on having the thimble pointing up (I guess you could have it facing down)?
Old Feb 3, 2015 | 06:47 AM
JE8154's Avatar
Is the winch recessed or mounted on top of the bumper?
Old Feb 3, 2015 | 06:52 AM
MAG00's Avatar
Winch is mounted in a JCR Crusader mid width bumper and is semi recessed.
Old Feb 3, 2015 | 06:56 AM
JE8154's Avatar
Personally I would just drill two holes for the license plate and call it a day. Don't see a reason to spend $170 to mount a license plate.
Old Feb 3, 2015 | 07:50 AM
espi's Avatar
I sandwiched my license plate between my orfab bumper and fairlead and it has plowed through ice filled puddles no problem. It did bend the plate back to form up to my bumper, but its been like that for a year.
