Spongy brakes after wheeling this weekend
Old Feb 3, 2015 | 04:37 PM
matthias2280's Avatar
Default Spongy brakes after wheeling this weekend
I took my jeep off the pavement for the first time this weekend and noticed that after the esc kicked on a few times my brake pedal felt spongy. It's a 14 jku with 7k on the clock. I have 35's and. 2.5bb. I checked for brake fluid leaks but none that I can see. Also I am not loosing any fluid from the reservoir. I should mention that I was in about 20" of mud. Seems the troubles started after that.
I went to the dealer today and they claim they can't feel the spongy pedal and all is well because the esc isn't throwing any codes. I call BS on all that as I know there is something not right. Any advice? Anyone seen this before? I cleaned the calipers and rotors thoroughly and I still have issues. I'm guessing the abs system had a bit of air trapped in it from a faulty factory bleed and that air has somehow made it into the brake lines. Any idea how I can convince my dealer that something is wrong?
Old Feb 4, 2015 | 03:41 AM
goaterguy's Avatar
I would start by bleeding the brakes as air in the brake lines is the #1 for the spongy feeling of the brake pedal. This is a cheap and relatively quick fix. Then you can determine if you need to proceed further with the dealer if the spongy feeling remains.
I am out of the country for the next couple of weeks but if you want to bleed the brakes and need help, let me know.
Good luck.
Old Feb 4, 2015 | 04:18 AM
jeepzz's Avatar
Mine did the same thing over a year ago when I took mine off-road the first time. They are still spongy and sometimes the abs will kick in on asphalt with a little sand on it. They never did any of this before. If you find something please pass along.
Old Feb 4, 2015 | 04:51 AM
Thanks man, I appreciate the response. I have bleed many a brake systems in my day but I really want the dealer to fess up and acknowledge that something isn't right. I'd bleed them myself but I don't have the software to do a ABS bleed. I am traveling for a few days next week so I may try to drop the jeep off at a different dealership. I tried Indian Trail Chrysler Jeep Dodge yesterday and they are insisting there is nothing wrong . I may try Keffer Jeep further up on 74. They sell a lot lifted Jeeps so maybe they will have a better understanding of what the brake pedal is supposed to feel like on a Jeep with 35's on it.
Old Feb 4, 2015 | 05:30 AM
I have an appointment for Monday night at Keffer Jeep. Lets see if they notice something is off... I'll keep you guys posted.
