OME piece together
Old Feb 4, 2015 | 05:49 PM
cody0707's Avatar
Default OME piece together
I purchased OME long travel shocks as well as some OME light Springs for the front and OME medium coils for the rear. I also have some front adjustable JKS quick disconnects already installed. If I install just the coils and shocks will I have any problems or should I order some other things to have a basic kit such as a rear track bar bracket?
Old Feb 5, 2015 | 11:28 AM
mikeJKUR's Avatar
How much lift are you expecting out of tholiftos coils?
Old Feb 5, 2015 | 12:41 PM
nthinuf's Avatar
Could you explain why you made those choices?
The way I see it, you are getting maybe 2" up front with the light coils, and probably 2.5-3" in the rear with medium coils. JK's start with a forward rake, so you are just making it worse. (unless you constantly carry a few tons of gear in back?).
The long travel shocks are the ones designed for 3-4" lifts? (roughly 11" collapsed, 27" extended?) Are you planning on relocating the upper shock mounts? Running a bunch of bumpstop to keep them from over-compressing and blowing out?
For you specific questions, no, you won't 'have' to buy anything else. But after driving it, you may decide that you want to. Axle centering can be a good thing. People tend to like having some form of caster correction. Longer brakelines or extension brackets can come in handy to keep them from ripping off the frame.
Old Feb 5, 2015 | 02:55 PM
D3ADLY's Avatar
This is an interesting build. Let me know how it feels driving it when you get it all put together! :p
Old Mar 22, 2015 | 04:17 PM
cody0707's Avatar
It has been awhile since I have checked this thread. The reason why I went with the light/medium coils is because I am not adding 100lbs worth of bumpers to the front and rear of my jeep. I have the springs and shocks installed now. I also installed a RK front adjustable trackbar and front lower control arms. I need to crawl under it and measure how much lift I gained overall. My next step is to fully flex it out and let it droop to see if longer brake lines are needed. On the road it handles great. I have wheeled it but when I do I have to leave my swaybar connected as it rubs pretty bad. My front flares have been chopped and I still need to do the rear. Longer bumpstops are on the way also.
