Tire Weight List?
Old Feb 8, 2015 | 06:50 PM
scafootballpro5's Avatar
Default Tire Weight List?
Okay so I'm looking for a list of tire weights for 35x12.50r15 tires. I have a set of General Grabbers that are just too damn heavy. 74lbs a piece. I know I can find some on Google but wasn't sure if one of the retailers would have a list of the tires available by weight? I'm sure it would help a lot of people even if it's not the same size tires by comparison!
Old Feb 8, 2015 | 06:51 PM
Sjanov94's Avatar
If you look on tire rack they have they weight of each tire in the specs by size
Old Feb 8, 2015 | 06:55 PM
I saw that, but still a comparison from lightest to heaviest would be cool. Or a sort by option!
Old Feb 8, 2015 | 08:35 PM
TheDirtman's Avatar
Why don't you go ahead and work on that and post it up when you are done. Make sure you include all the different wheel sizes as well.
Old Feb 9, 2015 | 07:04 AM
If I get time between classes and work I'll make a list for 35x12.50r17 tires as they seem to be the most common. Then the list could be used as a comparison for other sizes as well as the weights should be proportional among sizes.
Old Feb 9, 2015 | 09:01 AM
mr_alex2's Avatar
By the way, if you're looking for light tires. The AT2 General Grabber is the lightest 35 tire that I know of. 315/70/17 - are 59lb. I think the next one is the Duratrac, 60lb.
Good luck with the list.
Old Feb 9, 2015 | 09:05 AM
Sjanov94's Avatar
From what I know the mastercraft courser mxt is a lighter mt tire. Check that one out
Old Feb 9, 2015 | 12:39 PM
Originally Posted by mr_alex2
By the way, if you're looking for light tires. The AT2 General Grabber is the lightest 35 tire that I know of. 315/70/17 - are 59lb. I think the next one is the Duratrac, 60lb. Good luck with the list.
I'm looking for more of an M/T but I do know that both that and the BFG AT are really light. I would get the Duratracs but they don't make a 35 for 15s sadly...
Old Feb 9, 2015 | 12:40 PM
I have seen that tire and the price would be perfect for me. I was unsure of the weight however.
Old Feb 9, 2015 | 05:16 PM
Sjanov94's Avatar
According to treaddepot.com it weighs 60 pounds in the size you want, which isn't bad.
