3.5 inch lift
I had the RC 3.5" lift on my 09' JKU and didnt have any issues at full flex with stock rubi or 35" tires. Only thing is If i disconnected the sway bar the DS would def hit the trans pan so i never disco'd
If/when the boot on joint at the tcase end of the shaft wears through, it won't be a catastrophic failure. It will just start slinging grease.
The ring of grease is very easy to see. As long as you make crawling underneath and looking part of your normal maintenance, you will have plenty of time to decide what to do. There are rebuild kits, and lots of take-offs floating around from people who have upgraded, and many options for aftermarket shafts if you decide to go that route.
RK
