Trouble changing stock bulbs to led's.
So I decided to change out every single bulb from the crappy incandescent to led on my 2010 JK and ran into a problem. So I changed every one of them out and installed resistors. Only problem now is that when my headlight knob is in normal off position the lights in the rear both blink no matter which way, left or right. The front work fine. But when I use the blinker with the headlight knob on or just parking lights they all work fine. Going to do some more checking with light meter and see if I just put resistor on wrong wire or something. Thanks!
