Swaybar Disconnect park bracket issues...
Old Feb 15, 2015 | 08:06 PM
J33P_JK_08's Avatar
Default Swaybar Disconnect park bracket issues...
I've installed some swaybar disconnects on my 08 JK Unlimited and when I go to put on the park bracket, I can't because it has to go on the bolt that connects the body to the frame just behind the front grille. When I try to loosen that bolt, the rubber grommet that connects it all just wants to turn, and I cannot get anything on it to hold it. What can I do?
Thanks!!
Old Feb 16, 2015 | 03:46 AM
Rebar-7's Avatar
Do you have the Teraflex setup ? As far as the boltt goes try using a small pry bar to put pressure
On the bushing . Sometimes it helps to use a air impact just because of the spin force..
Old Feb 16, 2015 | 08:16 AM
J33P_JK_08's Avatar
I do have the teraflex setup, yes. They have a good youtube video that I watched, but that dang bolt on the body mount is ridiculous.
Old Feb 16, 2015 | 10:40 AM
Rebar-7's Avatar
Yep they can be a pain. Like said though if you can get some kind of pressure on the bolt or bushing
It will really help. You definitely don't want to break one of those bolts off they are a B_ _ ch to fix.
Using just a regular ratchet wrench is sometimes just to slow of a movement to get the bolt to come loose.
