New Clutch?
Old Feb 17, 2015 | 05:48 AM
SWFL's Avatar
Default New Clutch?
Occassionally having difficulty getting into first gear and having to put it in second first. 2010 Jeep Jk with 38k on odometer. Is it likely the clutch is going already?
Old Feb 17, 2015 | 06:16 AM
kbp810's Avatar
Sounds more like synchros to me.
Old Feb 17, 2015 | 06:36 AM
MotoJeeper's Avatar
Veteran: Marine Corp
Is this from a standstill, or while moving? I usually don't shift into first while moving because the gearing is so low. It doesn't sound like a clutch problem though. If it is a syncro though, you just have to rev match.
Old Feb 17, 2015 | 07:26 AM
SWFL's Avatar
This is from a stand still. If at a red light i take foot off everything and keep it in neutral until light changes.
Old Feb 17, 2015 | 08:45 AM
kfast24's Avatar
Ya sounds like syncros. If your still under warranty look it up under service bulletin 21-002-12.
Edit: this was for 2011-2012 there should be one for 07-10 but can't find the tsb right now
Old Feb 17, 2015 | 09:45 AM
SWFL's Avatar
Will do thanks. How about the chance of changing tranny fluid helping?
Old Feb 17, 2015 | 09:50 AM
Mad Dog 21's Avatar
This should help
Mad Dog 21's Avatar
Second page
Old Feb 17, 2015 | 11:08 AM
Cuv's Avatar
Cuv
For what it's worth, my jeep wouldn't/had a really hard time going into 2nd for a long time, nearly impossible in the winter. I read somewhere to replace the gear oil with penzoil synchromesh and no shit its shifted fine since then.
Jeep is 08, oil swap was mid 2010 and that's all I use now.
Old Feb 17, 2015 | 11:56 AM
SWFL's Avatar
Originally Posted by Mad Dog 21
This should help
Awesome. Any way I can get that sent larger ? email or link? Having trouble making out all the words.
