Changing spacers to coils
Old Feb 18, 2015 | 07:46 AM
BackinBlack07's Avatar
Default Changing spacers to coils
I currently have a rough country 2.5 spacer lift on my 07 two door (installed in 07 yikes!). I'd like to change the spacers to coils and only make that change. Is that an easy, smart swap? I have bilsteins installed that only have about 20k miles or less. Should I do 2.5 springs? Can I do 3 inch springs? Would change out the whole lift , but she's getting up in miles.
Old Feb 18, 2015 | 09:11 AM
redridge's Avatar
if you really need to... sure go ahead. Are the shocks meant for 2.5" lift? What do you do with the jeep that you need longer springs?
Old Feb 18, 2015 | 09:38 AM
It's probably mostly about ride quality, I believe new springs vs. the original ones with spacers will ride better (please correct me if I'm wrong). If I could go up to 3" lift coils I'd like to, to give me some more space and ride height. I wheel some, but mostly use the jeep to access trail heads.
Old Feb 18, 2015 | 09:54 AM
redridge's Avatar
were the shocks part of the 2.5" spacers, if not where did it come from? If it came from a 2.5" lift then get the 2.5" coils etc... dont forget 2.5" bump stops.
Old Feb 18, 2015 | 09:57 AM
KVJK08's Avatar
I may be interested in your BB if you make the swap !
Old Feb 18, 2015 | 10:04 AM
arasco85's Avatar
Assuming you have proper shocks, sway bar links and trac bar brackets. Would be pretty easy.
Old Feb 18, 2015 | 11:09 AM
I added the shocks later, to replace the rough country ones that came with the kit. They're the 5100 bilsteins , think for a 2-4 inch lift so i thought they would be good even if I switched to 3" coils. So could I keep all the other components and just take out the stock coils and spacers and replace with new lifted coils ?
Old Feb 18, 2015 | 11:38 AM
redridge's Avatar
should be good to go... but it really is more involved now that you are lifting higher. Look at some of the 3" lift packages like AEV or Teraflex... that will give you an idea what is involved to do a proper lift. Just putting coils "may" be more comfortable ... but may not be as driver friendly since the suspension geometry has changed.
Old Feb 18, 2015 | 11:47 AM
arasco85's Avatar
extended away bar links?
Old Feb 18, 2015 | 11:50 AM
tarpon4me's Avatar
JK-Forum Ambassador
If it were me, i'd use 2" coils, not 2.5. You're going to get over 2" of lift out of a 2" coil (I did), and you won't have the worry of drive line issues. If you want to go to a 2.5" or 3" kit, you're going to need drop brackets, longer brake lines up front, and other goodies to do it right.
