Undercoating metal flares question - when painting body match color
Old Feb 18, 2015 | 10:37 AM
Bobby G's Avatar
Default Undercoating metal flares question - when painting body match color
Question for the guys who run metal flares and body match paint.
I have a white JKU and am getting my PS crusher flares painted match white. The painter suggested undercoating underneath (the bottom inside of the flare). Do you prime, then undercoat and then rattle match white underneath. Short of it, i dont want the bottom of my fender black and the top white and also want to make sure i do any rust prevention I can.....
Sorry for what might be a dumb question but I just don't have any experience with this.
Bobby
Old Feb 18, 2015 | 11:21 AM
mattgt5's Avatar
I painted mine blue and the tube section and underneath grey. If I had white, I would do the tube and under in black. Blends well with the wheel well.
sent from my work leash
Old Feb 18, 2015 | 11:46 AM
MotoJeeper's Avatar
Veteran: Marine Corp
Bobby
If they're already painted, sand the underside with 180 grit or something, wipe with alcohol or prep spray and spray on bedliner. Just be sure to mask everything you don't want lined. Bedliner is a PITA to get off.
Old Feb 18, 2015 | 12:42 PM
101gargoyles's Avatar
Former Member
Bobby
Hey Bobby
The only dumb questions are those that are never asked.
If you are receiving them painted then the guy is talking about undercoating and It's not a hard coat paint. Go to NAPA/UAP and ask for a couple of spray cans of 'black-out' or 'undercoat' . The factory uses this stuff sprayed on by robots in wheel wells and most areas on chassis exposed to gravel problems.
The stuff is a soft sticky coating that sacrifices rather than the metal taking the hits. Bed liner is hard and brittle and will chip off in wheel wells. Truck beds look good with bedliner because they don't have stones chucked at them at the speed of spinning wheels.
Then again...your choice
Old Feb 18, 2015 | 02:23 PM
MotoJeeper's Avatar
Originally Posted by 101gargoyles
Hey Bobby
I don't know, I bedlined my rear wheel wells when I cut my fenders in June. I've done some wheeling and quite a bit of dirt and gravel road driving and it hasn't chipped at all. You just have to prep it right. If you follow the directions on the can to a tee, you'll get the best adhesion.
Old Feb 18, 2015 | 04:07 PM
Ronson's Avatar
I had mine painted also the rocks from the front tires chipped all the paint from the front of the rear flares. Had to get them Line-x no problems since.
Old Feb 18, 2015 | 05:07 PM
Bobby G's Avatar
Thank you for all the feedback...I appreciate it.
I want to keep underneath white so I guess it will be undercoat then rattle can white.....i guess it will be easy to touch up too when needed.
I like the linex idea too....never thought of that.
Old Feb 18, 2015 | 05:20 PM
TURTLECON's Avatar
Thank you for all the feedback...I appreciate it. I want to keep underneath white so I guess it will be undercoat then rattle can white.....i guess it will be easy to touch up too when needed. I like the linex idea too....never thought of that.
It won't stay white for long. It gets pretty dirty fast and the upkeep could drive you nuts.
