Sway Bar Nut Size
Old Feb 19, 2015 | 08:43 AM
NJKURPat's Avatar
Default Sway Bar Nut Size
While flexing out on Monday I went to check all my brake lines and clearance and noticed my passenger side sway bar link was loose. Upon inspection the upper nut was gone. I'm running metal cloak solid links and the stock nuts fit. I just don't know the size, thread, etc to get a replacement. Anyone know the size or know where to get a new one?
Old Feb 19, 2015 | 12:22 PM
mattgt5's Avatar
They take an 18 mm wrench, would assume a standard thread, def not fine thread.
sent from my work leash
Old Feb 19, 2015 | 03:47 PM
Ncb's Avatar
Ncb
Take the bolt or link into a hardware store and get a replacement nut, or maybe someone will chime in who knows.
Old Feb 20, 2015 | 08:45 AM
NJKURPat's Avatar
It's a flange style nut too and the local advanced doesn't have it
Old Feb 20, 2015 | 08:55 AM
jadmt's Avatar
JK-Forum Ambassador
12mm 1.5mm pitch
Old Feb 20, 2015 | 10:23 AM
Maertz's Avatar
Originally Posted by jadmt
12mm 1.5mm pitch
Looks like it IS fine thread then.
Old Feb 20, 2015 | 01:37 PM
jadmt's Avatar
JK-Forum Ambassador
I think I lied. the lower bolt/nut is 12mm 1.5 the upper stud nut is 12mm but not fine thread. Quadratech lists them as the same but they are not.
