one ton swap question gm14 bolt
Old Feb 20, 2015 | 05:36 AM
jager00's Avatar
Default one ton swap question gm14 bolt
So I'm trying to to a gm14 bolt swap in the rear. I found one that was on a gm p30 box truck? Is that going to work. I heard it may be to narrow for a jk. I couldn't find length specs on the p30 version. Help!!! Thanks
Old Feb 20, 2015 | 04:22 PM
2climbbig's Avatar
Are you wanting to put coil overs back there or are you sticking with the current setup
