SUPER CHARGER VS TRANSMISSIONS 2007-2011 3.8 auto
Old Feb 22, 2015 | 12:44 PM
rj'sjeep's Avatar
Default SUPER CHARGER VS TRANSMISSIONS 2007-2011 3.8 auto
When you who've done this is the power too much for the stock auto transmission? Have any of you had trans failures as result of installing a super charger?
Old Feb 22, 2015 | 02:47 PM
Smashboogie 4x4's Avatar
Former Vendor
Add a good cooler and you should be OK.
Old Feb 22, 2015 | 04:49 PM
haydhess's Avatar
I've had a ripp sc on my 09 auto for almost 3 years now and have never had an issue
Old Feb 22, 2015 | 06:27 PM
janders82's Avatar
x2. aux trans cooler is a must IMO.
Old Feb 23, 2015 | 01:53 AM
Kojack's Avatar
Like anything, if you abuse it, it will break. If you treat it right, you should have no issue. Trans cooler and good fluid is a must.
Old Feb 23, 2015 | 04:29 AM
blockrockin's Avatar
had a few ripp supercharges... never had a issue.. but yes trans cooler is a great idea.
Old Feb 25, 2015 | 12:30 PM
RIPPMODS's Avatar
Sponsoring Manufacturer
Making sure your rig is properly geared for the tire size you are running is the most important thing you can do to keep your 3.8 4 speed auto together. A trans cooler would just add that much more security in those high load situations!
RIPP
