Front Bumpstop Pad To Far Out Of Alignment at Full Compression
Old Feb 23, 2015 | 11:24 AM
Ajkaz's Avatar
Default Front Bumpstop Pad To Far Out Of Alignment at Full Compression
Check this out, I pulled out my TF 2.75" front upper bump stop extensions while welding in my gussets. I compressed the suspension nearly all the way, in the pic I still have 1" of shock compression left! How can these be re aligned? It could be my AEV geometry brackets? Nothing is binding at full compression except this... Should I just put the extensions back in and get 3" longer shocks?
Old Feb 23, 2015 | 11:30 AM
mikeJKUR's Avatar
Looks like your sway bar links are still attached.
Old Feb 23, 2015 | 11:39 AM
Ajkaz's Avatar
They are, but do you think that would cause the bumpstop and pad to malign?
Old Feb 23, 2015 | 12:05 PM
nthinuf's Avatar
What is your caster set at? (you profile shows brackets and adj upper arms?) Tilting the housing (lowering the pinion/raising the caster) causes the lower stops to tilt further and further back.
So, lowering the caster/raising the pinion would tilt the stops back upright. (again, depending on what the caster is set at now.) Or maybe adding lower arms and moving the whole housing forward?
