mopar remote start installed in 2010 jku with half doors, no power locks or windows?
So I got a killer deal on a mopar remote start and want to install it but now I am reading all the old posts saying you cannot. Do we know for certain? Has anyone accomplished this? Also I have one key and don't know if that is going to bring up more problems...
Please help! It's cold!!!!
Not sure if this will help you, but my '08 JKUR came with remote start + hardtop w/full steel doors. I found a set of half doors and installed the inner wiring harnesses for the full doors with pwr locks & windows, just left the window wires unconnected. Works like a charm now with remote start & the half doors. Pwr locks work, too. I think remote start locks the doors before turning over the engine, so (this is a wild guess) you may have to switch out the door wiring to the pwr lock type to make it work, else it won't complete it's cycle prior to starting.
The one thing I didn't have to do but felt it would help functionality in the long run was to add a manual power door lock switch to the front doors. I had to cut the inner door panel, but it wasn't because I was too lazy to lock all the doors from the inside. The auto lock & unlock features periodically reset themselves. The only way to re-program them is to actuate the pdls after turning on the ignition switch four times. Well, if there's not one on the half doors, guess what. You have to put the full doors back on just to active the pdls. It doesn't look all that great, but no one notices they're even there. I'd recommend adding them, though, especially if you don't have full doors to use to re-program. That is, of course, provided yours has the auto lock/unlock feature.
