Different gears front/rear and no front drive shaft?
Looking at getting a used rear D44 Rubi axle that has 5.13 gears, but I have 4.10s up front. Am I ok to drive like that IF I REMOVE the front drive shaft until I can re-gear my front axle? or can this not be done? Had a bunch of people say it's fine but I'm not wanting to grenade anything. Thanks!
No front drive shaft and you will be fine. You would even be fine if you left the front driveshaft installed and just did not engage 4 wheel drive. Since the driveshaft is so easy to remove it is a good precaution to take so it can't be accidentally put into 4 wheel drive.
But why not just wait to install the rear axle when the front is re-geared? This way if you have the itch to go wheeling you still can.
Great, thanks guys.
Smash, the reason I don't wait is I'll be installing the axles myself to save a bunch of money. To have a shop do it is at least $400 and I'm plenty capable to DIY. Then I will at least be able to still get around while I wait to re-gear the front, and I'll also actually be putting a Rubicon front 44 in as well.
Gotta love the Saharacon!
Makes sense. You could still wait until you are close to having the gears done then install it this way you still have your 4wd for as long as possible. It would just be a shame if you need 4wd and don't have it.
Great, thanks guys.
You just want an excuse to get under your jeep, don't you?
