mce fender, 35'' tires and 2.5 lift
Old Mar 7, 2015 | 10:10 AM
madmaths's Avatar
Default mce fender, 35'' tires and 2.5 lift
HI! I have a 2015 rubicon and just order my 315/75-16 toyo mt and some wheels 16'' wheel -5mm ( 4.30 back space ) I also order a 2.5 lift kit terralex ( full kit shock and coil ) and I'm planning to order some MCE flate fenders I was wondering if at full flex ( sway bar disconnected the max flex! ) with this recipe I will be rub free!? ( I also have a 1'' poly performance body lift kit but I'm very not sure id I want to install it! I'm planning to resell it but I keep it in back up....)
If any one have similar set up please share some pics!!
thanks
Old Mar 9, 2015 | 09:56 AM
Wildpeakjeep's Avatar
You should clear just fine. We ran a similar set up with 37's and a levelling kit w/MCE fenders and the only thing the tires would just graze at full flex (swaybar disconnected) was the fender support bracket up inside the front wheelwell. You're running a smaller tire and likely the Tera kit has an extended bumpstop so it's doubtful you'll have any rubbing whatsoever.
Old Mar 9, 2015 | 12:58 PM
madmaths's Avatar
Thanks buddy! I just placed my order on mce fender! thanks!
Old Mar 9, 2015 | 02:25 PM
khickeyman's Avatar
MCE fenders with 2.5" 315/70/17 . I haven't had any problems.
Old Mar 9, 2015 | 04:17 PM
mikeJKUR's Avatar
37s and a leveling kit. Oh I would like to see that. Sounds awesome.
Old Mar 9, 2015 | 04:24 PM
madmaths's Avatar
Attachment 600501
nice set up! I love it!! have you any sway bar disconnect? at full flex you never had any rubbing?
thanks for taking the time to share a pics!
Old Mar 9, 2015 | 04:54 PM
khickeyman's Avatar
I have JKS quick disconnects and no rubbing at full flex.
Old Mar 10, 2015 | 09:56 AM
This is in Moab last year. Disconnected front sway bar. 37 12.5 17 BFG's with a teraflex front spring leveling kit. Worked well, though breakover would be improved with a some lift. Super stable though off camber.
Old Mar 10, 2015 | 04:14 PM
madmaths's Avatar
I saw your jeep on Mce facebook page!! nice!
