Front Runner cargo slide in 2dr JK
Old Mar 16, 2015 | 08:46 AM
crusaderJK's Avatar
Default Front Runner cargo slide in 2dr JK
Just installed a Front Runner cargo slide in my JK.
They're actually designed to fit in the 4dr models. But with the rear seats removed and some minor modifications they fit the 2dr too.
The front left bracket clears the rear seat bracket.
The front right bracket has to be modified.
Made a cut-out...
...to clear the front right rear seat bracket.
Then I had to drill a hole into the tub on the left side...
Old Mar 16, 2015 | 08:57 AM
crusaderJK's Avatar
...and another one on the right side.
The slide is bolted to the tub through these holes and the factory cargo tie-downs in the rear of the cargo area.
The left hole is easily accessible from under the Jeep. The right hole sits over the rear end of the gas tank, but you still reach it with a wrench.
Installed
You can access the jack when the slide is closed.
With the slide open you can access the small cargo compartment.
Old Mar 19, 2015 | 10:21 AM
BryanFRO's Avatar
Originally Posted by crusaderJK
Attachment 601499
Attachment 601500
Installed
Attachment 601501
Attachment 601502
Attachment 601503
Looks Awesome!
Old Mar 19, 2015 | 11:36 AM
Cutman's Avatar
That's pretty sweet.
Old Apr 4, 2015 | 09:36 AM
crusaderJK's Avatar
Thanks guys. Cargo management is a work in progress.
I have built a cargo deck that rests on the slider's frame.
This way I can stack my luggage and still be able to pull out the slider with the cooler and other stuff.
ID:	604759Click image for larger version
Custom hooks a friend made for me. I gave him the dimensions so the holes line up with the bolts that hold the slider inside the frame.
A place to store the camp table.
Overall view
Tie-down rails on top.
Old Apr 4, 2015 | 11:42 AM
Muscles's Avatar
Former Member
what is the point of the cargo slider?
Old Apr 4, 2015 | 12:21 PM
crusaderJK's Avatar
Getting organized and having your stuff easily accessible on a longer trip. If you just stack all your luggage in the trunk, it will be difficult to get to stuff that's sitting deeper in that pile.
The goal is to get to almost every piece of equipment without moving other things around.
Old Apr 4, 2015 | 06:08 PM
JCDriller's Avatar
How much vertical height do you lose from the floor of the jeep to the floor of the slider?
Old Apr 5, 2015 | 11:43 AM
crusaderJK's Avatar
About 1 3/4".
