Dome light switch Help!!!
Old Mar 17, 2015 | 12:30 PM
oakleyoffroad's Avatar
Default Dome light switch Help!!!
I would like to hook my dome lights to one of my S pod switches ? and have searched the internet high and low. does anyone know how to do this? Thanks in advance.
Old Mar 17, 2015 | 01:21 PM
14Sport's Avatar
Wouldn't be hard. Cut the wire that feeds the dome lights, cap off the side coming from the dash, then run a wire from the side that goes to the dome to the sPod source. The dome will only work with the switch.
If you want the dome to work normally but on the switch also, then run a power wire from the source to the dome light as an alternate power wire.
I believe it's the yellow/white wire running down the passenger side that feeds the domes.
Of course, test it before you commit to it.
Mine is not to reason why, mine is but to do or die...or something like that.
