Procal module problem need help
Old Mar 17, 2015 | 04:42 PM
sacjku's Avatar
Default Procal module problem need help
Just got 4.56 gears installed. Used procal module double checked all the switches to adjust for new gear ratio. Got the 2 horn honks. Drove home about 15 miles. Check eng light came. It will nit shift above 3rd gear 60 mph turning 4600rpm. Will not let me shift manually (i have the auto trans). At one point would not let me go over 25mph. Was able to pull shut off and then could drive again. Trans not engaging as it should from a stop light. Please help with some advice
Old Mar 17, 2015 | 05:14 PM
Rebar-7's Avatar
Stay Calm and double check the toggle settings on Procal to the instructions.....
Old Mar 17, 2015 | 05:40 PM
sacjku's Avatar
Double and triple checked the switches
Old Mar 17, 2015 | 05:46 PM
nthinuf's Avatar
Are there any codes? Was a locker installed? Taller tires? Is the correct (measured) height programmed in? Speed sensors? (I am not up to speed on those, but have seen previous posts where they were the issue)
Did you drive it before programming with the procal? If so, same issues?
TacomanBJK12's Avatar
try disconnecting the battery then if if still is giving you problems try wiping the settings and going back to factory settings and do a test drive and see what happens.
Old Mar 17, 2015 | 06:01 PM
sacjku's Avatar
There are no codes, drove to the shop this morning before the work was done and all was fine. No speed sensors.
Old Mar 17, 2015 | 06:02 PM
sacjku's Avatar
Truetracs installed front and back also
Old Mar 17, 2015 | 06:53 PM
Rebar-7's Avatar
Yea I would set it back to stock and then maybe disco battery for a while like said...then try again..
Is there any chance they installed wrong gears ? ?....
Old Mar 17, 2015 | 08:00 PM
sacjku's Avatar
I am going to call AEV in the morning. I think there is an issue with the module as it will not even let me set back to factory
Old Mar 20, 2015 | 12:07 AM
RUBINOT's Avatar
What was the final outcome
