Oat, hoat, or other in aftermarket aluminum radiator with 2013 3.6 pentastar?
Looking at installing a Mishimoto MMRAD-WRA-07 in my 2013 JKUR unmodified 3.6 Pentastar simply because it appears to be more reliable (OEM has broken core).
My question is what coolant/antifreeze should I use in this all aluminum radiator now that all I have is the power train warranty? I am fairly certain that my JKUR came with OAT from the factory, though I am not sure what the real benefits are?
Thanks in advance.
Thanks in advance.
I'm running OAT in my '13 and my owners manual says to do so as well. The OAT is a purple colored antifreeze. I have no idea if others have strayed away from OAT and been successful doing so. Hopefully someone who has can chime in.
Thanks, I guess that it will not hurt anything sticking with OAT.
In researching this whole OAT thing, I learned that post-2011 (I believe) Zerex DEX-COOL OAT is the same as MOPAR OAT with a different dye color, and it says "5years/150,000 miles" instead of the 10 years/150,000 miles on the MOPAR OAT. I read it on the JeepForum.com
Leaning towards the Zerex DEX-COOL OAT as it is much cheaper and easier to access at most vendors (Walmart, Auto Parts Stores) than MOPAR OAT, which seems to only be available at the stealership. I guess it will not really matter what I put in since I am replacing the radiator and flushing-out the convoluted slurry that is in there now.
In researching this whole OAT thing, I learned that post-2011 (I believe) Zerex DEX-COOL OAT is the same as MOPAR OAT with a different dye color, and it says "5years/150,000 miles" instead of the 10 years/150,000 miles on the MOPAR OAT. I read it on the JeepForum.com Leaning towards the Zerex DEX-COOL OAT as it is much cheaper and easier to access at most vendors (Walmart, Auto Parts Stores) than MOPAR OAT, which seems to only be available at the stealership. I guess it will not really matter what I put in since I am replacing the radiator and flushing-out the convoluted slurry that is in there now.
http://articles.sae.org/11284/
