My DS
Old Mar 22, 2015 | 04:28 PM
ronixwrangler's Avatar
Default My DS
I have a RK 2.5 flex system on my jeep for over a year now. I do pretty much no crawling, just mudding and trail riding at the camp. Went mudding today and looked under my jeep "I haven't done that in a while" and idk something looks off, or is it just me... How does this look to you guys? Boot still in good condition.
Old Mar 22, 2015 | 04:43 PM
nthinuf's Avatar
Looks like you have a couple spots of grease up above the joint. When it gets to a big strip of grease, start figuring out what you want to do about it.
Old Mar 22, 2015 | 04:49 PM
Thanks, I seen the spots of grease and was like hmm...
Old Mar 22, 2015 | 05:18 PM
Only reason I looked under it was because I put it in 4wd today, I haven't put it in 4wd in about 6 months. Is that why it sprayed that little grease?
Old Mar 22, 2015 | 05:25 PM
Beemerman's Avatar
That looks normal. I went to a double cardon rear driveshaft. Yours looks like mine did before I changed. Mine is a 2 door automatic.. Yours looks like one also from the angle. I also had a very mild vibration. Almost unnoticeable. But I did have to go to adjustable upper rear control arms to get the correct angle. It seems the cv type driveshaft can take the angle. I just wanted to correct the mild vibration.
Sent from my iPad using JK-Forum
Old Mar 22, 2015 | 05:35 PM
Originally Posted by Beemerman
That looks normal. I went to a double cardon rear driveshaft. Yours looks like mine did before I changed. Mine is a 2 door automatic.. Yours looks like one also from the angle. I also had a very mild vibration. Almost unnoticeable. But I did have to go to adjustable upper rear control arms to get the correct angle. It seems the cv type driveshaft can take the angle. I just wanted to correct the mild vibration. Sent from my iPad using JK-Forum
Thanks, is this something I need to be worried with? Those couple grease specs?
Old Mar 22, 2015 | 05:44 PM
Beemerman's Avatar
I would not think it would be a big deal right now. But keep an eye on it. It had to come from that boot. When it gets worse you will see lots of grease. Then its decision time. Either a used stock shaft some one has removed. Or a double cardon.
Old Mar 22, 2015 | 05:46 PM
I would not think it would be a big deal right now. But keep an eye on it. It had to come from that boot. When it gets worse you will see lots of grease. Then its decision time. Either a used stock shaft some one has removed. Or a double cardon. Sent from my iPad using JK-Forum
Thanks, what am I looking price wise to replace? I would want an aftermarket. How much of a bitch is it to do myself? Thanks
Old Mar 22, 2015 | 05:55 PM
Beemerman's Avatar
Tom woods website is www.4xshaft.com Sent from my iPad using JK-Forum
Also lots of good info on angles and such
Old Mar 22, 2015 | 06:13 PM
Tom woods website is www.4xshaft.com Sent from my iPad using JK-Forum Also lots of good info on angles and such
Thanks!
