Teraflex flex arm rebuild question
Old Mar 25, 2015 | 04:24 PM
BoraBora's Avatar
Default Teraflex flex arm rebuild question
Hey guys,
Just bought a '15 JK 2dr Sport a few days ago and am currently in the process of ordering parts. A good friend of mine is going to sell me 8 Teraflex short flex arms, but the only catch is all the bushings are pretty shot.
My question is, should I rebuild the arms with Teraflex bushings or use something else? I've read that the flex bushing end can be replaced with any other rod end that uses 1.25 x 12 tpi. What about the clevite bushing end?
Any suggestions?
I'm planning on pairing these arms with Metalcloak dual rate 2.5" springs, track bars...etc.
Old Mar 25, 2015 | 05:31 PM
Silver Bullet's Avatar
Good question, which I would like to hear what others say as well. I have an 2007 JKU with a Teraflex 4" suspension system that's be on my jeep for the better part of 6 years. In those years I've put about 45,000 miles on my jeep, which is mostly hard use rock crawling. The joints have been making quite a bit of noise so it's time for a DIY rebuild on both ends of all 8 control arms. I have the tools from Teraflex, so just need to order their rebuild kit and get started before heading to Moab over Labor Day.
I figure 35,000 miles isn't too bad, but before I go through the effort of rebuilding the joints and replacing the clevite bushings, I would like to hear comments on the difficulty of the rebuild, vs replacing the joints from a different manufacturer?
BTW...cost is a factor.
Old Mar 25, 2015 | 07:11 PM
ronin2120's Avatar
Vet Army
I'm running TF flex arms and I just rebuilt mine. They had about 40,000 miles on them and needed to be rebuilt. I rebuilt all six of my control arms (3 link rear) in one night using the TF tool and a vice mounted trail hitch. I would highly recommend a high quality snap ring plier, the harbor freight ones I used made the night frustratingly longer then it needed to be.
FYI - If you have the TF catalogue you can piece together what you need to rebuild your arms and it comes out to be a bit cheaper then ordering the entire kit.
Old Mar 26, 2015 | 08:45 AM
TeraFlex's Avatar
Sponsoring Manufacturer
They really are not too bad to do, just time consuming.
https://www.youtube.com/watch?v=bEF-RWlLYG8 Link to 8 FlexArm rebuild kit: https://teraflex.com/shop_items/528f...d962f416e72e64
These will be back in stock in 1-2 weeks.
Large FlexJoint Rebuild tool :https://teraflex.com/shop_items/528f...d962f416e72e5d
Small FlexJoint Rebuild tool: https://teraflex.com/shop_items/528f...d962f416e72e5e
Now you don't have to use the tools, they just make things quite a bit easier. The clevite ends will need to be pressed out/in on a shop press.
I suggest that you use a good grease like Lucas Red N Tacky, which you can find at Home Depot. Also leave the grease zerks out until you have reassemble the flexjoint, this makes it easier to burp out any trapped air.
Joe
