Mounting superchips flashpaq
Old Mar 29, 2015 | 03:16 PM
sacamuelas's Avatar
Default Mounting superchips flashpaq
I'm considering mounting my flashpaq. This will allow me to quickly adjust all settings and lockers when out playing ( ex. Set high idle for winching/lock in 4H,etc) without having to get out and plug the tuner into the port. I'm thinking about an Apillar mounting location with an adjustable cell phone type holder positioning the tuner angled towards driver with permanent connection. Running the connection cable thru dash and securing it underneath so that it won't rattle/flex/get bumped when bouncing around off road.
Has anyone done this on their JK? If so, please give thoughts and parts you used. My Other Opton I was thinning about was the holder mounted in the center dash tray. This would put it on constant viewing of driver and I think I would prefer having it out of the way. Ideas...thoughts, suggestions....
Thanks
Old Mar 29, 2015 | 04:15 PM
DunnyBunny's Avatar
JK-Forum Ambassador
Whatever you do I would make sure it's hidden or you only use it when you decide to go out on trails. Otherwise it will likely be stolen.
Old Mar 30, 2015 | 04:31 AM
Level 10 Off Road's Avatar
Former Vendor
With the key on/off dance that you have to do when you change the ECU parameters, to me, puling it out of the glovebox and hooking it into the OBD port is the easiest part.
