p0455 code and coolant leak related?
Old Apr 3, 2015 | 04:10 PM
rj'sjeep's Avatar
Default p0455 code and coolant leak related?
Know the p0455 code means an evap leak or gas cap. Is it at all possible that a coolant leak from the condenser that started at almost the exact same time could throw this code? or is it just that they both started at the same time but are unrelated? wood a loose exhaust manifold cause this.. P0455 is supposed tone a large leak in the emission system. so I wouldn't think so.
Old Apr 3, 2015 | 04:17 PM
JeepersDigest's Avatar
Reference Source: P0455 Jeep EVAP System Large Leak OBDII Engine Light Trouble Code | Engine-Codes.com
Old Apr 3, 2015 | 04:35 PM
rj'sjeep's Avatar
Default did that
crawled under the vehicle checked the eval can no obvious leaks no cracks hoses nada, checked the gas cap seems ok can t smells retighened it and tried to bank the go ,,, no go... go the battery disconnected now waiting the 30 minutes to see if that will reset it.... we shall see
Old Apr 3, 2015 | 05:03 PM
rj'sjeep's Avatar
Default got the code reset
disconnecting the battery did the trick all is well except for the coolant leak
