35" tire on stock tire carrier?
Depending on your backspacing, one thing you can do to extend the life is to make sure the wheel doesn't wobble. Daystar sells aftermarket rubber bumpers to replace the stock ones that are longer and help hold the wheel steady.
Daystar KJ09144BK - Daystar Tailgate Bump Stops for 07-15 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
If your driving is all on-road or mild off-road, you'll be fine. I had my 35" on my stock carrier for the past 8 months with no issues. But I was advised that if I had plans to off-road it and bounce it around with any enthusiasm, I would be wise to get a proper tire carrier, as the bumps would warp the stock carrier and/or the tailgate. As I am taking it to the trails in June to Northern Ontario, I just picked up the Teraflex HD tire carrier. Easy install, and cheaper than many of the aftermarket bumper mounts. Hope this helps!
I agree with what everyone said. most of us have been in the same boat as you. when I got my new tire carrier and was taking of the stock one I was surprised how it could even hold up a 35' tire, its only made of pot metal and weighs about 3 pounds . and if it ever does break off I feel bad for the guy behind you on the highway . Teraflex does make a good carrier
I had the my 35 on my stock carrier and noticed the latch on the door starting to pop when I would open and close. I had it on for about 2 months with a decent amount of offroad. I just replaced with a Rancho tire carrier and feel at ease.
Had my 35" toyo MT on my factory tire carrier for about 3 months, then it started to rattle and sag to the point where I had to lift up on the door to keep it from scraping my rear bumper. I'm running around with the spare in the back while I save up for the Teraflex. Better safe than sorry
It will last a while, I've been running 35 for about a year but I just got the Evo carrier because my tail gate is a little wrapped from the tire but nothing to bad, but lately I've noticed every time I close the tail gate it wiggles. It should be fine for some light off roading but last time I went out I almost ripped out my whole tail gate!
