Which Rear Shafts and Splines to buy? (Confused)
Old Apr 25, 2015 | 07:01 AM
devwil68's Avatar
Default Which Rear Shafts and Splines to buy? (Confused)
I am looking to replace the rear axle shafts in my 2013 jk sport D44 axle.
I have to say I am really confused about which shafts to go with and what spline count to use ...and I know I want to get the bearings already pressed on. I am already re-geared to 4.88s as I am running 37s...
What company should I go with?
What spline count is required to work with my stock internals and G2 4.88s?
I found over @ Northridge that Ten Factory has a setup for the rear which is 30 spline Chromoly...would this be a good choice?
Ten Factory JK Non-Rubicon, 30 Spline, Dana 44 Rear Chromoly Axle Kit - TENMG22156-PRESSBEARING
Would appreciate any help I can get!
Old Apr 25, 2015 | 07:15 AM
JE8154's Avatar
30 spline. 10 factory and I believe g2 have the best warranties. Don't bother with nitro I remember seeing somewhere they don't warranty flanges
Old Apr 25, 2015 | 05:57 PM
Rebar-7's Avatar
I run G2 shafts no probs but had to have seal and bearings put on separate . You can order Ten Factory with everything pressed on
Ready to go for a good price. 30 spline rear.....
Old Apr 25, 2015 | 06:31 PM
nthinuf's Avatar
Some people like to move up to 35 spline (with 35spline lockers), others stay with 30 spline and use the stocks as trail spares. I stayed with 30 spline, but I guess it depends on use/weight/etc.
This info may have changed since I was looking a year and a half ago, but here is what I found for the rear 30 spline shafts:
Ten Factory and G2 - 10 year, flanges are covered.
Nitro - 5 year, flanges and bent/twisted shafts not covered. (Shaft has to break in two.)
Alloy USA - 10 year, didn't get a reply from them on the flanges.
Yukon - Lifetime warranty for mfg defects. 'Verbal' that trail damage is covered. But, they were cut to fit, not specific lengths for the JK.
TenFactory - 4140
G2 - 4140
AlloyUSA - 4140 or 4340 (they weren't very clear on this for the JK application)
Yukon - 4340
Nitro - 4130
And there are also differences in single/dual/triple bolt patterns.
Old Apr 26, 2015 | 03:36 AM
Invest2m4's Avatar
Originally Posted by nthinuf
Some people like to move up to 35 spline, others stay with 30 spline and use the stocks as trail spares. I stayed with 30 spline, but I guess it depends on use/weight/etc. This info may have changed since I was looking a year and a half ago, but here is what I found for the rear 30 spline shafts: Ten Factory and G2 - 10 year, flanges are covered. Nitro - 5 year, flanges and bent/twisted shafts not covered. (Shaft has to break in two.) Alloy USA - 10 year, didn't get a reply from them on the flanges. Yukon - Lifetime warranty for mfg defects. 'Verbal' that trail damage is covered. But, they were cut to fit, not specific lengths for the JK. TenFactory - 4140 G2 - 4140 AlloyUSA - 4140 or 4340 (they weren't very clear on this for the JK application) Yukon - 4340 Nitro - 4130 And there are also differences in single/dual/triple bolt patterns.
You can't just put a different spline shaft in. You need to change out the internals (locker, etc) to accept the spline change.
Old Apr 26, 2015 | 07:09 AM
DJ1's Avatar
DJ1
Former Member
Yup. Got to have the correct carrier/locker/LSD in also to accept the higher spline count...
Old Apr 26, 2015 | 07:11 AM
DJ1's Avatar
DJ1
Former Member
I'm personally going to upgrade to the Ten Factory's but stick with the stock spline count for my Sahara just so I can have a set of trail spares when I take the stock axle shafts out...
Old Apr 26, 2015 | 12:13 PM
nthinuf's Avatar
Yep, I should have mentioned that I was thinking 35 spline arb at the time, and this subject usually comes up in conjunction with a "which locker should I get" question.
