Synergy Trackbar and Synergy Axle side bracket.. pinch/gap
Old Apr 28, 2015 | 02:03 PM
feroxjb's Avatar
Default Synergy Trackbar and Synergy Axle side bracket.. pinch/gap
Is the bracket supposed to pinch down on the trackbar? Big gap/pinch between the inside of the bracket and the trackbar joint...
Old Apr 28, 2015 | 02:50 PM
kjeeper10's Avatar
Vet Army
My track bar does. Drag link and tie rod don't.
Old Apr 28, 2015 | 09:21 PM
feroxjb's Avatar
Like this?Click image for larger version
Old Apr 28, 2015 | 09:23 PM
feroxjb's Avatar
Aiiii cripey!
Was I supposed to use these in that joint and run the bolt through them??
Old Apr 29, 2015 | 12:56 AM
kjeeper10's Avatar
Vet Army
Originally Posted by feroxjb
Aiiii cripey! Was I supposed to use these in that joint and run the bolt through them?? <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=608658"/>
Yes .. Those are misalignment spacers to allow the joint to twist...
Also .. Center the joint up before you tighten the pinch bolt.
Old Apr 29, 2015 | 06:25 AM
SoK66's Avatar
Originally Posted by kjeeper10
Yes .. Those are misalignment spacers to allow the joint to twist... Also .. Center the joint up before you tighten the pinch bolt.
X2. Probably should remove the bracket to straighten the ears. Be sure no welds break.
