Lower control arm correction brackets?
Old Apr 29, 2015 | 03:51 AM
metaldemon's Avatar
Default Lower control arm correction brackets?
Several companies sell these brackets (AEV, Rancho, JKS). I am leaning toward the JKS brackets because they seem like the best made with welded construction. Plus I already have their track bar, and diconnects. They are both beefy. Anyone have these, or maybe the AEV ones?
Old Apr 29, 2015 | 04:40 AM
DunnyBunny's Avatar
JK-Forum Ambassador
I ran the AEV ones for a while and they are just as good. Kjeeper10 ran the rancho for a while and liked them a little better because they are a one piece design. They all pretty much do the same thing and are just as good as the other.
Old Apr 29, 2015 | 04:55 AM
kjeeper10's Avatar
Vet Army
Rancho/JKS
The JKS look narrower where the LCA bolts too.
ID:	608673   Click image for larger version
Old Apr 29, 2015 | 05:18 AM
ConroeJK's Avatar
I have had the AEV brackets for over a year, they are solid and work as advertised. I think AEV was the first on the scene with these, looks like a couple of manufacturers came out with some exact copies pretty fast and now some companies are coming out with the one piece kits.
Old Apr 29, 2015 | 06:43 AM
kjeeper10's Avatar
Vet Army
actually i believe Rancho was. AEV used cam bolts in the beginning.
Ol' Bob's Avatar
I know this was not the question, but.. While at a jeeping event this past week I observed a lot of lifted jeeps getting stuck up on rocks. It appeared that the jeeps were lifted high enough, but had correction brackets hanging low. A lot of the money that was put in the lift appeared to have been somewhat limited by these types of brackets.
For an extra $179 ($279 price) you could buy Rockcrawler hi Clearance lower control arms. I'm sure that there are other quality brands that cost even less (rubicon express, teraflex, etc..) I truly believe in the long run you would be more satisfied by going in that direction. In the grand scheme of things this really isn't a lot of extra money.
Either way, good luck on whatever you decide to do. Cheers....
Old Apr 29, 2015 | 03:19 PM
ConroeJK's Avatar
Originally Posted by Ol' Bob
I know this was not the question, but.. While at a jeeping event this past week I observed a lot of lifted jeeps getting stuck up on rocks. It appeared that the jeeps were lifted high enough, but had correction brackets hanging low. A lot of the money that was put in the lift appeared to have been somewhat limited by these types of brackets. For an extra $179 ($279 price) you could buy Rockcrawler hi Clearance lower control arms. I'm sure that there are other quality brands that cost even less (rubicon express, teraflex, etc..) I truly believe in the long run you would be more satisfied by going in that direction. In the grand scheme of things this really isn't a lot of extra money. Either way, good luck on whatever you decide to do. Cheers....
I would agree if max clearance is a concern the brackets would not be the way to go.
