Oracle LED Fog Lights with ColorSHIFT LED Halo Ring
Old Apr 29, 2015 | 04:55 AM
Morris4x4Center's Avatar
Sponsoring Vendor
Default Oracle LED Fog Lights with ColorSHIFT LED Halo Ring
ORACLE ColorSHIFT Lighting Technology uses 5050 3-Chip LED/SMD
(Light Emitting Diode/Surface Mount Diode) with RGB capabilities
to allow the user to change their rings to hundreds of different
color options. These halos have an expected life of 100,000 hours
that will outlast your vehicle. The expected output from the LED/SMD
halo rings is an intense bright illumination. ColorSHIFT LED/SMD
Halos do not require power inverters, they operate from the 12V
current of your vehicle.
Oracle Pre-Installed Depo LED Fog Lights with ColorSHIFT LED Halo Ring - Pair - OL-7159-333
Enter to win a 2015 Jeep JK Unlimited!
Jeep Giveaway 2015
Old Jan 1, 2020 | 03:41 PM
Ryan Hynko's Avatar
Default Similar issue
I just received a warning for my DRL in Florida being another color other than white or Amber. So I wired the power wire for the halos into my switch pod, now I have better control than my phone for turning them off and making sure they are off but when I use the turn signal all 4 halos flash. Does anyone know what I can do to fix this or am I going to have to disconnect them from the turn signals?
