Engine Transmisson skid plate
Old May 3, 2015 | 04:56 AM
BeachJK's Avatar
Default Engine Transmisson skid plate
Any one make there own. Most cost between $250-$350. Got to be able to do it at home for a fraction of that price. I've been looking for some Home made write ups or pointers.
If anyone has links or knowledge about doing it yourself, it would be appreciated.
So stuff like this doesn't happen again.
Old May 3, 2015 | 05:05 AM
Wrangeler X's Avatar
Material is the key... Good skids are made from the right metals.
Old May 3, 2015 | 06:16 AM
BeachJK's Avatar
I was thinking 1/4" steel, that's why I'm asking. To much, not enough, where have people used front mounting points.
I'm hopping someone's done this at home before so that has already trouble shot the speed bumps.
Old May 3, 2015 | 09:32 AM
BeachJK's Avatar
Bump
There's got to be someone on here that's done it
Old May 3, 2015 | 10:38 AM
Maertz's Avatar
I haven't yet, but when i do im using 1/4 plate. Possibly 3/16 with some uhmw on the bottom. I have it all planned/ measured just havent done it. Mine will go together somewhat like the artec if im recalling how theres was made. I will be flanging off by the motor and probably a brace off the tranny crossmember also.
Old May 3, 2015 | 11:12 AM
BeachJK's Avatar
Do it and take pic and write it up, your a pioneer, apparently. Looking forward to it!
Old May 5, 2015 | 07:31 AM
Maertz's Avatar
If i do itll be in my build thread. Mine will vary though as my belly has been modified and ill likely tie them together...
Old May 5, 2015 | 08:47 AM
Invest2m4's Avatar
I had the EVO stuff and was looking at it the other day. Would probably take me a couple hours to make copies of the design and maybe $50 worth of steel. However, like Maertz, I have a flat belly now, so my skid won't need any bends (except have to weld up a little ramp for one little part of the t-case).
